I have a linksys WRT54GS which is 6+ years old that I have been using as a router, mainly wired, for many years. I moved to a different location on my property and hooked it back up, no problem. I then went to buy a new, longer cable to run out of the way. After hooking this cable up, my router isn't showing me any connection to the modem at all. Next, I went and tried the old cable that I had been using for a few days, but it also isn't showing any connection on the router( the new cable I ordered seems to be damaged somehow, but the old one is plugged directly into my PC at this time). My next thought might be that my old router could have seen an unfortunate end, so I went and bought a new linksys n300. There doesn't seem to be any differences in my results to plugging either cable into the new router either.
I am baffled as to how the cable could work perfectly plugged directly into my pc, but doesn't even show any lights when I plug it into either router. I really need to be using the router so I was wondering if anyone had any thoughts on this.
