How far you can go with 1.85v depends on:
A. The core stepping of the CPU you have.
and
B. The cooling you use.
If you get an AGOIA XP1600+ its entirely likely that you can get up to XP2000 to XP2200+ speeds easily, as that CPU is a great overclocker.
Other chips vary.
My AGOGA XP1800+ is no where near as good, needing 1.85v just to get up to XP2000+, a jump of only 133Mhz.
The first tbred XP2200+ chips wernt very good either, barely getting an extra 100 to 200Mhz.
The new XP2400+ tbred revision B chips are better though, some people getting 300Mhz out of them.
<b>The Intel Celleron 2.1 & 2.2Ghz processors provide consumers with a great way to get on the Internet. Which one of the 478 pins plug into the phone socket? - <i>Intel & The Inquirer</i></b>
