[SOLVED] ITX Upgrade Help
OllympianGamer
317
50
18,890
My build is the following -
Fractal core 500
3900x
2080 Duke
B350 Asus Strix Gaming-I
Evga 550 gm
2 x m.2 ssd
Cooler masterliquid lite 120mm
So basically I want to upgrade the cooling solution, can either fit a 240mm or 280mm aio on the roof.
I think this psu is close to its limit ( about 500w) so think I will get a 650w gm but if I'm taking that out I may as well just upgrade the motherboard as well.
So recommendations for cooling solutions and itx motherboards are greatly appreciated preferably while keeping 2 x m.2 slots but not essential.
https://pcpartpicker.com/list/nrRkjp
Motherboard supposedly has 2 m.2 slots, probably hidden under the chipset heatsync.
This aio punches above its weight class apparently.
Thanks for the recommendation, I went to buy that motherboard but my local big distributor was out of stock so I bought a x570 Rog Strix, a corsair h100x and a 850w riotoro psu.
Reactions: NightHawkRMX
