I've decided to build a pc and i got a budget of 1800 - 2000 dollars. 4k is not important and I need a monitor that supports i
RawHundreds
Commendable
Mar 21, 2016
I've decided to build a pc and i got a budget of 1800 - 2000 dollars. 4k is not important and I need a monitor that supports it. The thing is that i know nothing about building a pc. I play FPS games, RPGs, MMOs. Almost a bit of everything 😀? So could someone please help me with the components and a monitor that good? Best regards
This will run most everything at ultra/max settings and 90+FPS (higher demanding games) Monitor goes up to 144hz as well so you can see up to 144 FPS.
You do not need an i7, don't ask.
CPU: *Intel Core i5-6600K 3.5GHz Quad-Core Processor ($238.89 @ OutletPC)
CPU Cooler: Noctua NH-D14 65.0 CFM CPU Cooler ($72.79 @ Amazon)
Motherboard: MSI Z170A-G45 GAMING ATX LGA1151 Motherboard ($169.99 @ Amazon)
Memory: *Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory ($76.99 @ Newegg)
Storage: Samsung 850 EVO 500GB M.2-2280 Solid State Drive ($151.97 @ B&H)
Video Card: MSI GeForce GTX...
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card ($659.95 @ B&H)
Case: Phanteks Enthoo Pro M ATX Mid Tower Case ($79.99 @ Amazon)
Power Supply: EVGA SuperNOVA GS 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ Amazon)
Optical Drive: *LG GH24NSC0B DVD/CD Writer ($15.89 @ OutletPC)
Operating System: *Microsoft Windows 10 Home OEM (64-bit) ($87.37 @ Amazon)
Monitor: AOC G2460PG 144Hz 24.0" Monitor ($366.98 @ Newegg)
Total: $2000.80
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2016-03-21 12:51 EDT-0400
Building your own computer is easy. Building it takes 2-3 hours, and installing windows takes about 30mins to 45mins, and after that downloading and installing drivers takes another 30-45 mins. After all that, have it download windows updates at night, it may take a 2-4 passes to get them all.
Building a PC:
https://www.youtube.com/watch?v=VIF43-0mDk4
Installing Windows:
https://www.youtube.com/watch?v=4zAdwedmj1M
Protip for installing drivers safely, install them one at a time and restart the computer after each install to avoid breaking the OS, which can happen if you try to install them all at once.
