Question JBL500 soundbar bluetooth problem
Are you sure that there is not some power saver mode being applied.
In any case, start troubleshooting here:
https://www.guidingtech.com/fix-bluetooth-keeps-turning-off-on-windows-11/
Also look in Reliability History/Monitor. There may be some error code, warning, or even just an informational event being captured when Bluetooth disconnects.
ok, i did everything from that link, cant repeat what causes it to disconnects right now, im disabled (bedtiden)
nobody is around if the problem happens again, ill have to try causing it to disconnect later, thanks for the help
Latest posts
