JUDGE my system!
Thundershot
17
Hello, a friend gave me these recommendations. My budget is 1500$ and I wish to get the best bang for my buck, so if you see anything that can be improved tell me. I plan for this desktop to last me atleast 3 years with playing games with ease. I play on a tv 1920x1080, and plan to play titanfall on ultra, and to clusterfuck skyrim with mods and enbs. That's why I chose gtx 770 4gb, but I don't know if i should replace that with the gtx 780 3gb what would be better?
here it is
BY THE WAY I do live in CANADA so thing will look more expensive.
http://ca.pcpartpicker.com/p/39IJM
I'd say go for that and enjoy your new PC. The only thing I'd change is I think you can find a more efficient PSU if you keep looking. for 90 bucks, you should be able to find a gold standard at that same wattage.
Looks fine, although I would get a different motherboard, a 780 and a CPU cooler. I would also not spend that much on the case if you're going for bang for the buck, but that's just me lol the 770 is a great card, and those are all solid components, but not the best bang for the buck.
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($247.98 @ Amazon Canada)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($29.80 @ DirectCanada)
Motherboard: Gigabyte GA-Z87X-D3H ATX LGA1150 Motherboard ($125.99 @ NCIX)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($88.11 @ DirectCanada)
Storage: Crucial M500 120GB 2.5" Solid State Disk ($84.99 @ NCIX)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($62.99 @ Canada Computers)
Video Card: EVGA GeForce GTX 780 3GB Video Card ($549.99 @ Memory Express)
Case: NZXT Phantom 410 (Red) ATX Mid Tower Case ($119.98 @ Newegg Canada)
Power Supply: XFX 650W 80+ Bronze Certified ATX Power Supply ($79.99 @ NCIX)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($16.79 @ DirectCanada)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($99.99 @ NCIX)
Total: $1506.60
(Generated by PCPartPicker 2014-03-15 22:05 EDT-0400)
Added cpu cooler.
Cheaper motherboard, just as good.
Cheaper RAM, faster speed.
Stronger gpu.
My comment still stands. Look for a gold rated PSU. You should be able to find one for around that same price. In fact.....
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182071
You don't have to pick that one, but you should look around a bit more for a better PSU
It's all about the electric bill. It does make some difference. Also, if there's literally NO difference in price, why not get the more efficient one. Not to sound like an environmentalist freak, but it does help a little.
All about the electric bill? There's about a 5% difference in efficiency between bronze and gold. It's about the quality of the unit. If the same quality is the same price, then yeah, go for it. But it's not worth paying more money for higher efficiency for the normal person. The normal person may see a $1 difference per month. Maybe.
