Just added another graphics card with crossifre and it runs relatively hot in almost idle!
tbean1
68
Hello,
I recently decided to buy myself for my birthday another graphics card, Sapphire HD 7850 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102998, and I used crossfire. I know crossfire is working I have all the drivers and everything I need for that such as AMD Catalyst which tells me they are both working and I can read the different temps for both cards. However, this morning I brought my computer out of sleep and just watched some south park studios while eating breakfast. Both my cards were at 55 degrees C and I thought that was a little cause for concern. I figure that this is high for just running firefox. I have Windows 7 64-bit and a 750 power supply. My case is a Rosewill, http://www.newegg.com/Product/Product.aspx?Item=N82E16814102998. I have a 120mm blowing in on the front, one blowing air out the back and two 140 mm side by side and the side of the case. I also have one blowing air in on the bottom of the case because I put the case on it's side. Everything was cool when running just one card and last night I also played Far cry 3:Blood Dragon on Ultra with the hottest card reaching only 74 degrees. I was just curious if I have my fans setup badly, if I need a bigger case, or if there is something else I need to pay attention to! Also when my cards were at 55 degrees my CPU was around 32 degrees. Thanks for your time!
55 degrees idle is pretty high especially for a video card. 74 on load on the other hand isn't. Maybe you can tweak your fan speeds with MSI afterburner or a similar program.
Yeah, I thought about that! I was using speedfan to determine the temperature, however when I saw that it was really hot I thought it was just the program itself so I checked the AMD Catalyst and it had the same temp. I don't know what it is, but when I take my computer out of sleep it tends to run them hotter. After I restart and don't put into sleep they stay cool around the same as my CPU so I don't know what's going on there. I just discovered this at lunch today.
