Question Just build first PC - Getting no display and no power to front panel or MOBO USB's
Apr 7, 2020
28
Just built my first pc and cant seem to get it going
Build:
3800x (stock cooler)
Viii Hero
Trident z neo 32gb 16cl
1050ti (this is soon to be upgraded)
Nzxt h710i.
Got all fans and rgb going (ll120 corsair fans) except the ram which i anticipated would need configuring.
Cant get display or power to keyboard and mouse.
Ive completely unplugged all cables and re connected.
Dont want to try again without a knowing issue as once turned on i cant turn it off. Pressing the power button turns it on as expectrd but no matter how long i hold the button to turn off, it wont.
Please help, im working from home tomorrow and my old pc is shot.
What should i try? Let me know if you need more details.
Thanks
28
Additional information worth noting.
I have only put one 8 pin in the motherboard. Did not have a 4pin cable to add.
When mounting the motherboard in the case the middle bottom screw would not line up, so i left it out. With some brief research online it seemed to not be an issue.
Ive tried the two sticks in the 1st and 4th slotand then tried just 1 in the 4th slot as the manual specifies.
