and after I finished putting my components together I noticed there was no beeping at all and the usb slots failed to work which is strange because I had my usd 2.0 connector plugged in.I'm also not getting any signal from the monitor.Now i'm pretty sure there has to be a hardware problem,but i'm just not sure which component it is.The notch on my gpu onboard gpu still spins so I can assume it's working.I can hear my HDD and optical drive so I can count those out to.I'm pretty skeptical about my motherboard since it keeps giving me a red light even when I used one ram stick at a time.The psu is giving power to my fans and mobo but it still might be faulty.
As for my build, I have a Sabertooth z77 mobo,wester digital 500gb HD,CM Storm trooper full case,i5 3570k,gtx670 gpu and a cool master 750watt psu.I've had this issue for a while and really need help.
