I followed a step by step tutorial on Youtube, And the PC fires up. Fans work, all lights up and looks good however when I plug it into the Monitor it says "Power Saving Mode"
Its also a LG Monitor.
When your monitor dispalys the power saving icon it usually means that it is not recieving a signal from your PC. Unfortunately you haven't given enough information to enable me to help you. Are you using a dedicated graphics card and does your mother board have on board graphics?
I'm betting you are having the same problem I had when I built my first rig. Make sure you have the proper plugs from you power supply to your graphics card and make sure you have a power supply that has enough juice.
Dude the same thing is happening to me. I've gone through the checklist and everything. I have a A88x Ac motherboard, A8 7650k CPU with integrated graphics. I,m connecting DVI and it keeps going into sleep mode.
I have the same issue as him but I have an integrated graphics. I'm connected DVI and it still won't show up
