G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.elitegroup (More info?)
Just built a K7VTA3 Rev6. PC 2700 Mem. Althon XP ... I am at home and
this box is at the office...so I can not recall exact processor ...
266 bus.
The problem is heat related ... it works fine with the case open.
I have redone the northbridge with artic silver... the processor also
artic silver.
Put a little heat sink on the PLL chip as it felt a little warm.
The case is an enlight front fan blowing in and rear fan blowing out
Case open... MBM reads processor temp a 44C if I close the case the
freeze occurs at 49-50C ... which seems low for this type of problem
Any ideas would be of great help.
Thanks
David
266 bus.
artic silver.
Thanks
David
