K7X/W2k - Other PCI Bridge Device driver problem
dick
358
Archived from groups: alt.comp.periphs.mainboard.tyan (More info?)
I have installed Windows 2000 Pro on a server with a Tyan Thunder K7X
(S2468) motherboard.
I keep getting a "Other PCI Bridge Device" message on startup. I
cannot find any chipset drivers on Tyan's site that fixes this
problem.
Anyone else run into this and found a solution?
Rich
> problem.
In addition to all chipset, board drivers, are you sure everything
connected to the board has an up to date, Win2k Pro driver?
Bryan
> Rich
On Fri, 25 Feb 2005 13:56:58 -0500, Bryan Hoover <bhoover@wecs.com>
>> problem.
>Bryan
>> Rich
Found the solution - it was a power management driver. Found the right
driver on AMD's website
>>> problem.
>>Bryan
>>> Rich
I am having the same problem. Would you post the link to that driver
please?
Thanks.
Well I found and installed it and it resolves the problem with the
device. Any idea what the device is supposed to do?
AFAIK, it's, uhm, power management. The "green" stuff -- hibernate,
standby, and like that. FAIK I figure anyway.
Bryan
On Sun, 27 Feb 2005 09:57:00 -0500, Bryan Hoover <bhoover@wecs.com>
>Bryan
Thanks that's about what I figured too. Doesn't seem to be any effect
here (S2466) with it on or off that I can see anyway.
> >Bryan
There are also options in the bios (s2462 anyway). I assume OS
environment software takes precedence -- in Windows there are options
from the Power button on the Screen Saver tab of Display Properties.
The various modes, on wake up, lock up my system -- I assume I have one
or more expansion cards that are not conforming to the standard.
Bryan
On Mon, 28 Feb 2005 13:46:57 -0500, Bryan Hoover <bhoover@wecs.com>
>Bryan
Option settings haven't had any noticeable effect at all on my S2466. I
had been hoping that I'd get this windows2000 machine to power down on
exit which I never did get to work when it was on a S2460.
