K8NS Pro SATA problem
Chris
2,048
Archived from groups: alt.comp.periphs.mainboard.gigabyte (More info?)
i have a K8NS Pro and just got a SATA drive (120GB) when i plug the drive
in my current windows wont load, as in it wont even commence loading
there is 4 sata connections
SATA0_SB
SATA1_SB
SATA0_II
SATA1_II
if i plug the drive into SATA0_II OR SATA1_II it will detect and i can
install windows on it. (with no other drives present)
But if i commect the drive to SATA0_SB OR SATA1_SB it wont detect at all -
any idea why ??
could the motherboard be faulty ??
i have checked the bios settigns and ONBOARD SATA is enabled and SERIAL ATA
FUNCTION is set to base
and ideas would be great
thanks
> SATA0_SB
> SATA1_SB
> SATA0_II
> SATA1_II
> any idea why ??
> thanks
The bios is kind of backwards on the GB - the onboard sata acutally
refers to the SATA0_II and SATA1_II you talk about. This is the add in
SATA. The SATA0 and SATA1 are the Nvidia sata connections, I beleive
they are actually set up in the IDE section of the bios (I had this MOBO
but not any more so I am trying to remember).
