G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
I have been searching for solutions for my memory problem with my MSI K8T
Neo2-F motherboard on various online forums. It seems like several people
are having similar memory issues with this board but I have not found a
solution. I have 2 Kingston Value RAM 512MB PC3200 chips. The only way I can
keep my system from shutting down and running smoothly is to use only one of
the memory chips, either one. Whenever I use 2 chips regardless of which
dimm slot combination I use, my system runs unstable if it boots at all. I
have tried all of the slot combinations for both single and dual channel
that MSI says can be used. I purchased all of the components for this system
new a week ago. The components also include an AMD 64 3000 CPU, ATI 9800
A-I-W Pro video card and 350w Antec power supply. The only items not new are
the drives and the mid-tower case. I have flashed to the latest BIOS, 3.20.
I very much appreciate suggestions from anyone. Thanks
Eddie
Eddie
