[SOLVED] Keep replacing thermal paste, but not working
dbqkd
5
Hello guys,
I’m using TS140 as NAS server with Intel Xeon E3-1225 v3 3.2GHz, running 24/7 almost 5 years. It keeps shutting down recently. I have replaced power supply and applied new thermal paste:
  • First thermal paste applied lasts for few months
  • Second thermal paste applied lasts for few weeks
  • Third thermal paste applied lasts for few days
Is it the thermal paste issue? Or something else?
Any idea how to fix it?
Thanks
Tried a new power supply, but having thesame issue. How do I know if it is cpu or mainboard? Anyway to test it?
Thanks
Gotcha. Unfortunately, you would need to swap the motherboard or cpu for a 'known working' part. I would take the cpu and put it in another system and test it there. If it works 100%, which I suspect it would, then motherboard is the culprit.
Is something vibrating causing the thermal paste to break. Maybe use better thermal paste everyone is a critic with thermal paste i use Artic Silver 5
Thanks
Thanks SamirD,
I have bought a new system for now.
I will try it out to find out defective part.
