I've updated all my drivers, installed all windows updates bar one which continually fails and my system heat is a continual ~30C, yet my computer freezes every time I run a game! Here's the MiniToolBox dump; MiniToolBox by Farbar Version: 25-07-2015 01
Ran by Fearghall (administrator) on 31-07-2015 at 12:16:59
Running from "C:\Users\Fearghall\Downloads"
Microsoft Windows 7 Home Premium Service Pack 1 (X64)
Model: MS-7693 Manufacturer: MSI
Boot Mode: Normal
========================= Flush DNS: ===================================
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
========================= IE Proxy Settings: ==============================
Proxy is not enabled.
No Proxy Server is set.
"Reset IE Proxy Settings": IE Proxy Settings were reset.
========================= Hosts content: =================================
========================= IP Configuration: ================================
Gigabit PCI Express Network Adapter = Local Area Connection 2 (Connected)
Killer e2200 Gigabit Ethernet Controller (NDIS 6.30) = Local Area Connection (Media disconnected)
# IPv4 Configuration
pushd interface ipv4
reset
set global icmpredirects=enabled
popd
# End of IPv4 configuration
Host Name . . . . . . . . . . . . : Fearghall-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : lan
Ethernet adapter Local Area Connection 2:
Connection-specific DNS Suffix . : lan
Description . . . . . . . . . . . : Gigabit PCI Express Network Adapter
Physical Address. . . . . . . . . : 30-B5-C2-01-17-C1
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::3030:b35b:99cb:f9a5%13(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.111(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 31 July 2015 11:47:42
Lease Expires . . . . . . . . . . : 01 August 2015 11:47:41
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 389068226
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-4A-BC-FB-D8-CB-8A-5E-33-7E
DNS Servers . . . . . . . . . . . : fe80::9e97:26ff:fec3:323c%13
192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Killer e2200 Gigabit Ethernet Controller (NDIS 6.30)
Physical Address. . . . . . . . . : D8-CB-8A-5E-33-7E
Tunnel adapter isatap.{E17E9A93-19D1-495E-8344-BBFF1C2D87A7}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.lan:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
Server: dsldevice.lan
Address: fe80::9e97:26ff:fec3:323c
Addresses: 2a00:1450:4009:80b::200e
216.58.209.238
Pinging google.com [216.58.208.46] with 32 bytes of data:
Reply from 216.58.208.46: bytes=32 time=17ms TTL=56
Reply from 216.58.208.46: bytes=32 time=16ms TTL=56
Ping statistics for 216.58.208.46:
Packets: Sent = 2, Received = 2, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 16ms, Maximum = 17ms, Average = 16ms
Addresses: 2001:4998:58:c02::a9
2001:4998:44:204::a7
2001:4998:c:a06::2:4008
98.139.183.24
206.190.36.45
98.138.253.109
Pinging yahoo.com [98.139.183.24] with 32 bytes of data:
Reply from 98.139.183.24: bytes=32 time=108ms TTL=49
Reply from 98.139.183.24: bytes=32 time=105ms TTL=49
Ping statistics for 98.139.183.24:
Minimum = 105ms, Maximum = 108ms, Average = 106ms
Pinging 127.0.0.1 with 32 bytes of data:
Reply from 127.0.0.1: bytes=32 time<1ms TTL=128
Ping statistics for 127.0.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
Interface List
13...30 b5 c2 01 17 c1 ......Gigabit PCI Express Network Adapter
11...d8 cb 8a 5e 33 7e ......Killer e2200 Gigabit Ethernet Controller (NDIS 6.30)
1...........................Software Loopback Interface 1
12...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter
14...00 00 00 00 00 00 00 e0 Microsoft ISATAP Adapter #2
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.1.254 192.168.1.111 20
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.1.0 255.255.255.0 On-link 192.168.1.111 276
192.168.1.111 255.255.255.255 On-link 192.168.1.111 276
192.168.1.255 255.255.255.255 On-link 192.168.1.111 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.1.111 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.1.111 276
Persistent Routes:
None
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
13 276 fe80::/64 On-link
13 276 fe80::3030:b35b:99cb:f9a5/128
On-link
1 306 ff00::/8 On-link
13 276 ff00::/8 On-link
Persistent Routes:
None
========================= Winsock entries =====================================
Catalog5 01 C:\Windows\SysWOW64\NLAapi.dll [52224] (Microsoft Corporation)
Catalog5 02 C:\Windows\SysWOW64\napinsp.dll [52224] (Microsoft Corporation)
Catalog5 03 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 04 C:\Windows\SysWOW64\pnrpnsp.dll [65024] (Microsoft Corporation)
Catalog5 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog5 06 C:\Windows\SysWOW64\winrnr.dll [20992] (Microsoft Corporation)
Catalog9 01 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 02 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 03 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 04 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 05 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 06 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 07 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 08 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 09 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
Catalog9 10 C:\Windows\SysWOW64\mswsock.dll [231424] (Microsoft Corporation)
x64-Catalog5 01 C:\Windows\System32\NLAapi.dll [70656] (Microsoft Corporation)
x64-Catalog5 02 C:\Windows\System32\napinsp.dll [68096] (Microsoft Corporation)
x64-Catalog5 03 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 04 C:\Windows\System32\pnrpnsp.dll [86016] (Microsoft Corporation)
x64-Catalog5 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog5 06 C:\Windows\System32\winrnr.dll [28672] (Microsoft Corporation)
x64-Catalog9 01 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 02 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 03 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 04 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 05 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 06 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 07 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 08 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 09 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
x64-Catalog9 10 C:\Windows\System32\mswsock.dll [327168] (Microsoft Corporation)
========================= Event log errors: ===============================
Application errors:
Error: (07/31/2015 12:13:33 PM) (Source: Microsoft-Windows-LoadPerf) (User: Fearghall-PC)
Description: Unloading the performance counter strings for service Windows Workflow Foundation 4.0.0.0 (Windows Workflow Foundation 4.0.0.0) failed. The first DWORD in the Data section contains the error code.
Description: The performance strings in the Performance registry value is corrupted when process Performance extension counter provider. The BaseIndex value from the Performance registry is the first DWORD in the Data section, LastCounter value is the second DWORD in the Data section, and LastHelp value is the third DWORD in the Data section.
Error: (07/31/2015 12:13:25 PM) (Source: Microsoft-Windows-LoadPerf) (User: Fearghall-PC)
Description: Unloading the performance counter strings for service MSDTC Bridge 4.0.0.0 (MSDTC Bridge 4.0.0.0) failed. The first DWORD in the Data section contains the error code.
Error: (07/31/2015 12:13:24 PM) (Source: Microsoft-Windows-LoadPerf) (User: Fearghall-PC)
Description: Unloading the performance counter strings for service SMSvcHost 4.0.0.0 (SMSvcHost 4.0.0.0) failed. The first DWORD in the Data section contains the error code.
System errors:
Error: (07/31/2015 11:47:36 AM) (Source: EventLog) (User: )
Description: The previous system shutdown at 11:35:50 on 31/07/2015 was unexpected.
Error: (07/31/2015 11:02:03 AM) (Source: Service Control Manager) (User: )
Description: The MSISuperIO_CC service terminated unexpectedly. It has done this 1 time(s).
Error: (07/31/2015 10:38:53 AM) (Source: Microsoft-Windows-WindowsUpdateClient) (User: NT AUTHORITY)
Description: Installation Failure: Windows failed to install the following update with error 0x80242016: Cumulative Security Update for Internet Explorer 8 for Windows 7 for x64-based Systems (KB3065822).
Error: (07/31/2015 10:34:09 AM) (Source: Service Control Manager) (User: )
Description: The Windows Modules Installer service terminated with the following error:
%%16405
Error: (07/31/2015 10:32:04 AM) (Source: Service Control Manager) (User: )
%%16405
Error: (07/31/2015 10:26:17 AM) (Source: Service Control Manager) (User: )
Description: The Avast Antivirus service failed to start due to the following error:
%%109
Error: (07/31/2015 10:26:15 AM) (Source: Service Control Manager) (User: )
Description: The NVIDIA Network Service service terminated unexpectedly. It has done this 1 time(s).
Error: (07/31/2015 10:26:14 AM) (Source: Service Control Manager) (User: )
Description: The MSI_SuperCharger service terminated unexpectedly. It has done this 1 time(s).
Description: The MSI_FastBoot service terminated unexpectedly. It has done this 1 time(s).
Description: The MSISMB_CC service terminated unexpectedly. It has done this 1 time(s).
Microsoft Office Sessions:
Error: (07/31/2015 12:13:33 PM) (Source: Microsoft-Windows-LoadPerf)(User: Fearghall-PC)
Description: Windows Workflow Foundation 4.0.0.0Windows Workflow Foundation 4.0.0.08F20300004D070000
Description: Performance1637070000000000000000000009030000
Error: (07/31/2015 12:13:25 PM) (Source: Microsoft-Windows-LoadPerf)(User: Fearghall-PC)
Description: MSDTC Bridge 4.0.0.0MSDTC Bridge 4.0.0.08F20300004D070000
Error: (07/31/2015 12:13:24 PM) (Source: Microsoft-Windows-LoadPerf)(User: Fearghall-PC)
Description: SMSvcHost 4.0.0.0SMSvcHost 4.0.0.08F20300004D070000
=========================== Installed Programs ============================
7-Zip 9.22 (x64 edition) (HKLM\...\{23170F69-40C1-2702-0922-000001000000}) (Version: 9.22.00.0 - Igor Pavlov)
Age of Empires II: HD Edition (HKLM-x32\...\Steam App 221380) (Version: - Hidden Path Entertainment, Ensemble Studios)
AMD Catalyst Install Manager (HKLM\...\{DD562794-C098-A1E5-66ED-10E8BD1C84C5}) (Version: 3.0.864.0 - Advanced Micro Devices, Inc.)
Avast Free Antivirus (HKLM-x32\...\Avast) (Version: 10.3.2225 - AVAST Software)
Banished (HKLM-x32\...\Steam App 242920) (Version: - Shining Rock Software LLC)
Battle.net (HKLM-x32\...\Battle.net) (Version: - Blizzard Entertainment)
Besiege (HKLM-x32\...\Steam App 346010) (Version: - Spiderling Studios)
Blender (HKLM\...\{EA3C8A99-1565-44FF-89FC-926CEEB623B5}) (Version: 2.75.1 - Blender Foundation)
Curse Client (HKCU\...\101a9f93b8f0bb6f) (Version: 5.1.1.844 - Curse)
Driver Booster 2.4 (HKLM-x32\...\Driver Booster_is1) (Version: 2.4 - IObit)
EasyViewer (HKLM-x32\...\{EECD7B96-1416-4D3A-B12D-0D2512120C36}) (Version: 1.3.0.9 - MSI) Hidden
EasyViewer (HKLM-x32\...\InstallShield_{EECD7B96-1416-4D3A-B12D-0D2512120C36}) (Version: 1.3.0.9 - MSI)
EVGA PrecisionX 16 (HKLM-x32\...\Steam App 268850) (Version: - EVGA)
Google Chrome (HKLM-x32\...\Google Chrome) (Version: 44.0.2403.125 - Google Inc.)
Google Update Helper (HKLM-x32\...\{60EC980A-BDA2-4CB6-A427-B07A5498B4CA}) (Version: 1.3.28.1 - Google Inc.) Hidden
Google Update Helper (HKLM-x32\...\{A92DAB39-4E2C-4304-9AB6-BC44E68B55E2}) (Version: 1.3.21.115 - Google Inc.) Hidden
Krita Desktop (x64) 2.9.6.3 (HKLM\...\{075BFD2E-33CB-4251-93CD-CD644A40C891}) (Version: 2.9.6.3 - Krita Foundation)
Live Update 5 (HKLM-x32\...\{E8BAA541-D161-4C9B-85BF-01F05A56BD7F}}_is1) (Version: 5.0.116 - MSI)
Microsoft .NET Framework 4.5.2 (HKLM\...\{92FB6C44-E685-45AD-9B20-CADF4CABA132} - 1033) (Version: 4.5.51209 - Microsoft Corporation)
Microsoft Visual C++ 2010 x64 Redistributable - 10.0.30319 (HKLM\...\{DA5E371C-6333-3D8A-93A4-6FD5B20BCC6E}) (Version: 10.0.30319 - Microsoft Corporation)
Microsoft Visual C++ 2010 x86 Redistributable - 10.0.40219 (HKLM-x32\...\{F0C3E5D1-1ADE-321E-8167-68EF0DE699A5}) (Version: 10.0.40219 - Microsoft Corporation)
Microsoft Visual C++ 2012 Redistributable (x86) - 11.0.61030 (HKLM-x32\...\{33d1fd90-4274-48a1-9bc1-97e33d9c2d6f}) (Version: 11.0.61030.0 - Microsoft Corporation)
MSI Command Center (HKLM-x32\...\{85A2564E-9ED9-448A-91E4-B9211EE58A08}_is1) (Version: 1.0.0.64 - MSI)
MSI Fast Boot (HKLM-x32\...\{0F212E7A-65EB-4668-A8D7-749026A64F8E}_is1) (Version: 1.0.1.3 - MSI)
MSI Super Charger (HKLM-x32\...\{7CDF10DD-A9B5-4DA3-AB95-E193248D4369}_is1) (Version: 1.2.025 - MSI)
NetworkGenie (HKLM-x32\...\{B416A23D-C2BD-4956-8BAE-5C3BAFF1AC1E}) (Version: 1.0.0.8 - MSI)
NVIDIA 3D Vision Controller Driver 352.65 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.NVIRUSB) (Version: 352.65 - NVIDIA Corporation)
NVIDIA 3D Vision Driver 353.62 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.3DVision) (Version: 353.62 - NVIDIA Corporation)
NVIDIA GeForce Experience 2.5.12.11 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.GFExperience) (Version: 2.5.12.11 - NVIDIA Corporation)
NVIDIA Graphics Driver 353.62 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.Driver) (Version: 353.62 - NVIDIA Corporation)
NVIDIA HD Audio Driver 1.3.34.3 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_HDAudio.Driver) (Version: 1.3.34.3 - NVIDIA Corporation)
NVIDIA PhysX System Software 9.15.0428 (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_Display.PhysX) (Version: 9.15.0428 - NVIDIA Corporation)
Platform (HKLM-x32\...\{20D4A895-748C-4D88-871C-FDB1695B0169}) (Version: 1.42 - VIA Technologies, Inc.) Hidden
Qualcomm Atheros Bandwidth Control Filter Driver (HKLM\...\{C80C9B28-CF99-431C-88C8-8B1F9B6A182F}) (Version: 1.1.39.1040 - Qualcomm Atheros) Hidden
Qualcomm Atheros Killer E220x Drivers (HKLM\...\{DD2A85B3-64C5-4263-A7AF-4F61FA5F369A}) (Version: 1.1.39.1040 - Qualcomm Atheros) Hidden
Qualcomm Atheros Killer Network Manager Suite (HKLM-x32\...\{E70DB50B-10B4-46BC-9DE2-AB8B49E061EE}) (Version: 1.1.39.1040 - Qualcomm Atheros)
Qualcomm Atheros Network Manager (HKLM\...\{7364C716-1212-4EAE-B0C9-A31D1E797BF8}) (Version: 1.1.39.1040 - Qualcomm Atheros) Hidden
Realtek Ethernet Controller Driver (HKLM-x32\...\{8833FFB6-5B0C-4764-81AA-06DFEED9A476}) (Version: 7.77.1126.2013 - Realtek)
Realtek High Definition Audio Driver (HKLM-x32\...\{F132AF7F-7BCA-4EDE-8A7C-958108FE7DBC}) (Version: 6.0.1.7541 - Realtek Semiconductor Corp.)
SHIELD Streaming (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_GFExperience.NvStreamSrv) (Version: 4.1.3000 - NVIDIA Corporation) Hidden
SHIELD Wireless Controller Driver (HKLM\...\{B2FE1952-0186-46C3-BAEC-A80AA35AC5B8}_ShieldWirelessController) (Version: 2.5.12.11 - NVIDIA Corporation) Hidden
Skype™ 7.7 (HKLM-x32\...\{24991BA0-F0EE-44AD-9CC8-5EC50AECF6B7}) (Version: 7.7.102 - Skype Technologies S.A.)
Sound Blaster Cinema 2 (HKLM-x32\...\{B4F6F8CC-2C61-42CC-A4CC-76621F25BDC7}) (Version: 1.00.06 - Creative Technology Limited)
Space Engineers (HKLM-x32\...\Steam App 244850) (Version: - Keen Software House)
Steam (HKLM-x32\...\Steam) (Version: 2.10.91.91 - Valve Corporation)
TeamingGenie (HKLM-x32\...\{AF9B9CCF-D1B4-44B4-A030-BFCF5686AA5E}_is1) (Version: 1.0.1.3 - MSI)
The Binding of Isaac: Rebirth (HKLM-x32\...\Steam App 250900) (Version: - Nicalis, Inc.)
The Elder Scrolls V: Skyrim (HKLM-x32\...\Steam App 72850) (Version: - Bethesda Game Studios)
The Witcher 2: Assassins of Kings Enhanced Edition (HKLM-x32\...\Steam App 20920) (Version: - CD PROJEKT RED)
Unigine Valley Benchmark version 1.0 (HKLM-x32\...\Unigine Valley Benchmark_is1) (Version: 1.0 - Unigine Corp.)
Unity (HKLM-x32\...\Unity) (Version: 5.1.2f1 - Unity Technologies ApS)
Unity Web Player (HKCU\...\UnityWebPlayer) (Version: 5.1.2f1 - Unity Technologies ApS)
Vegas Pro 13.0 (64-bit) (HKLM\...\{1EEE0BEE-0BC8-11E5-A19E-F04DA23A5C58}) (Version: 13.0.453 - Sony)
VIA Platform Device Manager (HKLM-x32\...\InstallShield_{20D4A895-748C-4D88-871C-FDB1695B0169}) (Version: 1.42 - VIA Technologies, Inc.)
VideoGenie (HKLM-x32\...\{FC54FD8D-789C-406D-BB88-F7C4421B7E83}_is1) (Version: 1.0.0.12 - MSI)
Wacom (HKLM\...\Pen Tablet Driver) (Version: 5.3.5-3 - Wacom Technology Corp.)
Warhammer® 40,000™: Dawn of War® II – Retribution™ (HKLM-x32\...\Steam App 56400) (Version: - Relic Entertainment)
WebTablet FB Plugin 32 bit (HKLM-x32\...\Wacom WebTabletPlugin for Internet Explorer and Netscape) (Version: 2.1.0.7 - Wacom Technology Corp.)
WebTablet FB Plugin 64 bit (HKLM\...\Wacom WebTabletPlugin for Internet Explorer and Netscape) (Version: 2.1.0.7 - Wacom Technology Corp.)
Winki (HKLM-x32\...\{81CF5153-38CF-41e2-AC3C-3D477C987D96}_is1) (Version: 3.2.131 - MSI)
World of Warcraft (HKLM-x32\...\World of Warcraft) (Version: - Blizzard Entertainment)
========================= Devices: ================================
Name: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Description: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
Class Guid: {4d36e96c-e325-11ce-bfc1-08002be10318}
Manufacturer: NVIDIA
Service: nvvad_WaveExtensible
Device ID: ROOT\UNNAMED_DEVICE\0000
Problem: : This device is disabled. (Code 22)
Resolution: In Device Manager, click "Action", and then click "Enable Device". This starts the Enable Device wizard. Follow the instructions.
========================= Memory info: ===================================
Percentage of memory in use: 60%
Total physical RAM: 8140.32 MB
Available physical RAM: 3240.79 MB
Total Virtual: 16278.82 MB
Available Virtual: 10529.66 MB
========================= Partitions: =====================================
1 Drive c: (PROGRAMS) (Fixed) (Total:931.41 GB) (Free:809.19 GB) NTFS
========================= Users: ========================================
User accounts for \\FEARGHALL-PC
Administrator Fearghall Guest
========================= Minidump Files ==================================
No minidump file found
========================= Restore Points ==================================
30-07-2015 18:03:43 Removed NVIDIA PhysX
30-07-2015 18:17:54 Device Driver Package Install: TP-LINK TECHNOLOGIES CO., LTD Network adapters
30-07-2015 19:20:06 Installed Krita Desktop (x64) 2.9.6.3
30-07-2015 19:33:35 Installed DirectX
30-07-2015 19:58:01 Windows Update
30-07-2015 21:45:13 Installed Microsoft Fix it 50123
30-07-2015 21:47:25 Windows Update
31-07-2015 09:39:08 Windows Update
31-07-2015 09:45:24 Driver Booster : AMD IOMMU Device
31-07-2015 10:08:45 Windows Update
31-07-2015 10:58:01 Windows Update
**** End of log ****
Any ideas? It also sometimes does weird stuff when turning on, like rebooting before starting and when i flip the psu switch, turning on for a second before shutting down.
Boot Mode: Normal
reset
popd
192.168.1.254
216.58.209.238
98.139.183.24
206.190.36.45
98.138.253.109
Interface List
IPv4 Route Table
Active Routes:
Persistent Routes:
None
IPv6 Route Table
Active Routes:
On-link
Persistent Routes:
None
Application errors:
System errors:
%%16405
%%16405
%%109
