Last couple months i've been having this issue, but i havent started looking into it until now. I have a dell XPS 13 9343.
The computer will randomly shut down, no warning, no nothing. It's not overheating because it would shut down even if im doing nothing on the computer and everything is closed. (completely random shutdowns actually)
Ive done all sorts of diagnostics to rule out things such as cpu, ram, hardrive etc.
The error im receiving is "Kernel-Power" Event Id 41, Task Category 63
Here are the details.
Log Name: System
Source: Microsoft-Windows-Kernel-Power
Date: 3/30/2017 11:15:51 AM
Event ID: 41
Task Category: (63)
Level: Critical
Keywords: (70368744177664),(2)
User: SYSTEM
Computer: DESKTOP-GCA11AP
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
<EventID>41</EventID>
<Version>4</Version>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Keywords>0x8000400000000002</Keywords>
<TimeCreated SystemTime="2017-03-30T15:15:51.542092300Z" />
<EventRecordID>8639</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="8" />
<Channel>System</Channel>
<Computer>DESKTOP-GCA11AP</Computer>
<Security UserID="S-1-5-18" />
</System>
<EventData>
<Data Name="BugcheckCode">0</Data>
<Data Name="BugcheckParameter1">0x0</Data>
<Data Name="BugcheckParameter2">0x0</Data>
<Data Name="BugcheckParameter3">0x0</Data>
<Data Name="BugcheckParameter4">0x0</Data>
<Data Name="SleepInProgress">6</Data>
<Data Name="PowerButtonTimestamp">131353604716805621</Data>
<Data Name="BootAppStatus">0</Data>
<Data Name="Checkpoint">0</Data>
<Data Name="ConnectedStandbyInProgress">false</Data>
<Data Name="SystemSleepTransitionsToOn">1</Data>
<Data Name="CsEntryScenarioInstanceId">0</Data>
</EventData>
</Event>
I should also mention that my power button isnt functioning, rarely does. The odd thing i found about the details is that there are no values for the bugcheckparameter. Could it be that my messed up button (which it sometimes will actuate and work, but VERY rarely) is the cause of this? could it be actuating on its own at random times because of the malfunction?
Furthermore, i did do powersupply stress tests but the computer didnt crash during those. not sure if i used a good program. if someone could recommend a good psu stress test program? But perhaps even a stress test wouldnt directly cause a bettery that has dying cells to crash?
Anyways, i would GREATLY appreciate the help in solving this issue. Im hoping its something as simple as changing the power button board/buying a new battery.
Thanks in advance.
Log Name: System
Event ID: 41
Task Category: (63)
Level: Critical
User: SYSTEM
Description:
Event Xml:
<System>
<Level>1</Level>
<Task>63</Task>
<Opcode>0</Opcode>
<Correlation />
</System>
<EventData>
</EventData>
</Event>
Thanks in advance.
