Hello,
So i recently bought a ducky SF one 2 and it worked great for awhile but then the keys would double click making gaming and typing horrible, so i cleaned it with air duster and thought it would fix it(it never did). So after re installing new drivers on it and everything else it still would double type horribly. Now i also had this issue with my Vulcan 120 AIMO keyboard that again worked perfectly for a good 5-6 months then the keys yet again have started to double type or straight up not register at all after hitting a few times. I RMA'd the ducky keyboard only to find out they said it was working perfectly on their end and they suspect it is a software issue on my end. I'm not sure what to do now cause i feel like both keyboards this expensive shouldnt have messed up like this. Ive plugged in a cheap 10$ walmart keyboard by surf on and its worked fine but my other two still have the issue. Im not sure if ram could play a role in this because i think my ram could also be bad cause everytime i try to take it over 2666 mhz my system freezes up and becomes choppy till i revert it back even tho it says it can go to 3200 mhz, i even only go up to maybe 2800 or even 2700 and it still does it. I'm fairly lost and frustrated by these keyboards failing me cause i really love them. I'm gonna test it on my gfs computer and see if the keyboards still mess up but what other steps should i take? should i replace my ram? re install windows 10 again? any help is appreciated thanks guys!
Specs:
rtx 2070 super EVGA black
B550 A pro mobo
1tb HDD
500gb SSD
750W g evga
Vengance LPX corsair ram 16gb (bought 5-6 years ago i think and used in 2 diff builds of my own)
Ryzen 3600 cpu
Specs:
B550 A pro mobo
1tb HDD
500gb SSD
750W g evga
Ryzen 3600 cpu
