I have this keyboard: https://www.amazon.com/E-Element-Mechanical-Dimmable-Keyboard-Conflict/dp/B01EFOJ0L6/
About a month ago it didn't wake up from sleep mode, I gently shook it and it came back on like it was supposed to
2 weeks later it shut off again while I was using it for no reason, gently shaking it didn't turn it back on this time
I plugged it into different USB ports but it didn't make a difference, I even tried plugging it into a different computer but it didn't turn on there either, eventually, in frustration i hit it on the back, behind the backspace key and it came back on
It has been turning off ever since then and hitting it on that spot turns it back on again but I keep having to hit that spot harder and more times before it will turn back on, it's also turning off more frequently, twice a day for the past 3 days
Today I had to bang on it multiple times much harder than I felt comfortable doing to get it to come back on again, so this problem is getting worse and eventually it won't come back on
I've tired to open it up, to get at the motherboard and maybe try to fix the problem internally, but it only has 2 screws on the front, unscrewing them doesn't actually loosen anything either, so I can't figure out how to open it
So my question is
What is actually happening internally and how can i fix it?
Thanks
So my question is
Thanks
