Question Keyboard works only if CPU is physically touched by human , earthing problem ?
Deepak Pundir
As tittle describe, Keyboard only works if CPU is physically in contact with human. As soon as I take my hand off the CPU, keyboard stop working.
No disagreement with @jay32267
However, you should not be touching the CPU inside of a powered up system.
Do not do that again.
If there are grounding/power problems then brushing against something else may not end well for you and/or the system.
Update your post to include full system hardware specs.
What case are you using?
Make and model keyboard - USB?
Do you have a multimeter and know how to use it? Or have a family member or friend who does?
Caution is advised.
Reactions: Deepak Pundir
