[SOLVED] Kindly asking for monitor advice
Antilein
5
Dear community,
i would like to upgrade to an WQHD Monitor.
I was lucky to get my hands on a 3080, and i would like to get that crispy wqhd image quality.
At the moment im using the BenQ ZOWIE XL2546.
I did try the Acer Predator XB271HUbmiprz 69 cm but i can feel the slower reaction time.
I tried to inform myself beforehand, but its too many options to be able to choose ( Ips/tn/va etc... )
Due to the fact that i play a lot of FPS games , i need a very reactive display.
Thank you very much for your help!
I am from Germany, Budget is 400-600 if i sell the BenQ. If there is an absolutely mindblowing option outside of my budget i would consider.
I'm not very familiar with monitor options in Germany. I would recommend you going to an actual store to scout around then try searching online for the monitor that you loved in the store.
I think that i should have access to most of the monitors through online stores.
I tried going to stores but sadly they mostly have very low quality monitors there, the higher quality expensive ones are only in the online stores so i cant do that.
Thanks
