[SOLVED] King of all 50' long-distance USB hubs and cables?
CZ Eddie
8
I'm looking for a USB 3.x hub that'll work for two 25' USB 2.0 runs and two 50' USB 3.x runs.
Mostly used for mouse & keyboard + future proofing.
Any suggestions?
My current Plugable® 7-Port USB 3.0 SuperSpeed Hub + these two 25' cables will randomly disconnect even though I'm just connecting a mouse & keyboard at the ends.
https://www.amazon.com/gp/product/B006HDAAC2/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00FFKIUJS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
In my opinion, the best cables you can get are those made by Eaton/Tripp-Lite, however, you are already exceeding the maximum length for USB 2.0 per specification by about four feet and are grossly exceeding the maximum length for USB 3.0.
IF a cable is going to fix the problem, I think a cable by Tripp-Lite is what you are going to want but you might very well want to think about using ACTIVE USB cables or USB over Cat5/Cat6 adapters for runs that long.
https://blog.tripplite.com/usb-cable-max-length
