[SOLVED] Kingston DT50 64GB writing speed and behavior
Jul 9, 2019
hi
any body know the reason or if there is any way to fix or improve this behavior
the writing to the USB is always looks like a sin wave and the speed is fluctuating as you can see in this picture
regards,
copy from the main hard drive to the USB drive on USB 2.0 Port , the issue here not max speed as the max speed in my case is Ok for USB 2.0 but the issue is the sin wave performance is down to 300KB
i have tested different ports on PC.
i also see the same effect when connected it to USB 3.1 Gen 1 port on laptop the sin wave is still there but the min and max speed is higher because of USB 3.1.
the main reason i have asked to know is this normal for all devices with same model and prand
o i just got a defected one.
Thats normal for that drive. It's got a small fast buffer but after that it drops to it's slow native speed and cycles up and down like that as the buffer fills & clears, over and over. It's like an old slow usb2 drive someone slapped a usb3 interface onto to get people to buy it.
edit - fopund a review demonstrating the same thing you're seeing: https://proclockers.com/reviews/sto...traveler-50-usb-31-gen1-drive-review/page/0/3
