[SOLVED] KMODE_EXCEPTION_NOT_HANDLED, and Dogwatch
Aug 22, 2020
4
Hello
So my pc has been experiencing blue screen just now. The couple of days back it was ok and no bluescreens happened, so i searched the internet on what should i do to do stuff but the blue screen is still occuring. Blue screens occur when im just doing some browsing in the web but it doesnt blue screen when i play games. Here is the minidumps and i hope it can help with you guys
my pc is a
msi a320m v2 pro
8gb 2400mhz ddr4 memory hyperx
1tb seagate hdd
gt1030
amd ryzen 2600x
and a 450w psu
HERE IS THE LINK OF THE MINIDUMPS
http://www.mediafire.com/file/84x1nkr6ut98ajc/Minidumps.rar/file
I should have been able to guess that one :)
Dumps aren't being helpful, so I will suggest old drivers that may have replacements
Logitech gaming software may be replaced by G Hub, depending on age of hardware. - https://www.logitechg.com/en-au/innovation/g-hub.html
check you have latest Occulus drivers
Does the game use Vanguard as we have seen vgk.sys cause BSOD in the last few weeks. I assume ram isn't running at 3200. It shows as 2400 in bios, just checking.
Newer version of lan driver - https://www.realtek.com/en/componen...0-1000m-gigabit-ethernet-pci-express-software
I have seen newer Nvidia drivers cause errors for 10 series cards but I don't normally see...
Hi, I ran the dump files through the debugger and got the following information: https://jsfiddle.net/b60a2mn1/show This link is for anyone wanting to help. You do not have to view it. It is safe to "run the fiddle" as the page asks.
File information:040990-50359-01.dmp (Aug 22 2020 - 09:58:01)
Bugcheck:KMODE_EXCEPTION_NOT_HANDLED (1E)
Probably caused by:ntkrnlmp.exe (Process: RiotClientUx.e)
Uptime:0 Day(s), 0 Hour(s), 15 Min(s), and 25 Sec(s)
File information:082220-49609-01.dmp (Aug 22 2020 - 09:35:24)
Bugcheck:DPC_WATCHDOG_VIOLATION (133)
Probably caused by:ntkrnlmp.exe (Process: svchost.exe)
Uptime:0 Day(s), 1 Hour(s), 58 Min(s), and 58 Sec(s)
File information:082220-38796-01.dmp (Aug 22 2020 - 06:31:19)
Probably caused by:memory_corruption (Process: System)
Uptime:0 Day(s), 0 Hour(s), 07 Min(s), and 22 Sec(s)
File information:082220-27500-01.dmp (Aug 22 2020 - 06:01:37)
Bugcheck:IRQL_NOT_LESS_OR_EQUAL (A)
Uptime:0 Day(s), 0 Hour(s), 05 Min(s), and 04 Sec(s)
File information:082220-26703-01.dmp (Aug 22 2020 - 05:50:20)
Uptime:0 Day(s), 0 Hour(s), 07 Min(s), and 41 Sec(s)
Possible Motherboard page: https://www.msi.com/Motherboard/A320M-PRO-M2-V2
You are using BIOS 3.4W (which isn't listed on the page). Maybe I have the wrong page, or the BIOS was removed from the page and replaced with a Beta.
This information can be used by others to help you. Someone else will post with more information. Please wait for additional answers. Good luck.
I have seen newer Nvidia drivers cause errors for 10 series cards but I don't normally see IRQ errors tied to Nvidia, so wait and see.
Im not a big fan of the g hub when sometimes it opens it doesnt detect the mouse and when i try to update it it just stops at unpacking package at 100 percent.
ok ill update the drivers
my ram is 2400 mhz speed can i overclock it?
fair enough with G Hub, it doesn't like my keyboard and won't run half the color schemes on it.
I don't think you can OC the ram.
ohh i see isee most of the blue screen happens when im just browsing chrome or any program that is not a game and frequently if i quit my game after a few minutes bsod appears
