KMODE_EXCEPTION_NOT_HANDLED (ndis.sys) BSOD Solution
Paullll
5
Is this the only way? I have seen other posts here and they were helpful to them. Something like MSI things to be uninstalled?
Try the system restore and choose a point way before it started, and then get back to us 🙂
I have restored my system to the farthest restore point it has, but still the same. Please help.
looked at 3 bugchecks, all were in sdgame.sys driver from 2012.
this could be a driver bug in sdgame.sys or in one of the custom hardware drivers for your machine.
so you should try to update both if you can.
looking at the most current bugcheck:
the driver:\C:\CherryDeGames\Dragon Nest\GPK\SDGame.sys
Timestamp: Tue Apr 17 21:18:12 2012
crashed but the stack is corrupted so this can be this driver messing up or another driver corrupting its data.
suspect drivers:
\SystemRoot\system32\DRIVERS\ETDI2C.sys Mon Apr 07 03:27:08 2014
(just not sure about this one, you might want to find out what it is)
you have other driver for your machine you might want to update or check for a update from your PC vendor.
machine info:
Vendor Insyde Corp.
BIOS Version V1.01
BIOS Release Date 04/14/2014
Manufacturer Acer
Product EA40_HB
Version Type2 - A01 Board Version
Processor Manufacturer Intel(R) Corporation
Processor ID 51060400fffbebbf
Processor Version Intel(R) Core(TM) i3-4030U CPU @ 1.90GHz
Processor Voltage 86h - 0.6V
External Clock 100MHz
Max Speed 1900MHz
Current Speed 800MHz
How do I update them? Or check for updates? I'm sorry I really don't know. The game is up to date and I don't know where to get an updated version of the sdgame.sys.
if you can not get a updated sdgame.sys then try and update your hardware drivers for your machine.
your machine has some custom hardware, unexpected bugs in the hardware drivers can cause other drivers to get errors that they don't handle correctly. Or you can uninstall the game driver or google on the driver name and see if other people are having the same problem and maybe a solution.
