Hello everyone.
I recently bought a Kraken x62 AIO and I installed it in my nzxt h710 case.
I followed the instructions to the letter:
-plugged the pump header in to the 4pin CPU fan header on the motherboard
-plugged in the SATA header to the PSU
-plugged in the first radiator fan to the 4pin and the second to the 3pin header that comes out of the cpu block
(so basically everything that the instruction manual says)
My problem now is that the fans are not spinning and do not even show up in nzxt CAM software (says 0 rpm there)
I tried messing around with the fan curve and nothing is happening
Anyone have any ideas to help me with this?
My motherboard is the Gigabyte z390 UD (all the headers on it work, I already checked)
If any other information is needed I will provide
EDIT: I connected the radiator fans to motherboard headers, they DO both work so the fans themselves are not the issue here, however, I want to control those fans through CAM software so this is NOT a solution
