Archived from groups: alt.comp.periphs.mainboard.abit (
More info?)
I had to try them all and found that it works at 9, thats what you see but
not what it is.
I am running mine at 2000 with the fsb bumped up 15
James
"Wes Newell" <w.newell@TAKEOUTverizon.net> wrote in message
news
😛an.2004.04.25.10.33.34.216109@TAKEOUTverizon.net...
> On Sat, 24 Apr 2004 20:55:34 +0000, Asestar wrote:
> > But won't that be then running at 1200MHz?
> > 9 * 133 = 1196..
> > I have a Duron 1600 (default unlocked core), running at 12,5*133 =
1662MHz.
> > My cpu has default core multiplier of 12. I run at maximum possible
setting
> > in bios, that's 12,5.
> > Wes told that if your cpu has default core multiplier of 13 or higher,
AND
> > it's unlocked, bios lets you choose multiplier up to 23? I have no
option to
> > confirm this.
> > See if your bios support higher rate.
> The bios will still show the old values since it knows nothing about the
> higher multipliers and doesn't even know about the 5th (8x) multiplier
> bit. There's a cross reference table at the site below. But I'm pretty
> sure it won't matter with his 1800 Duron as it's surely locked.
> Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
