G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.msi-microstar (More info?)
Installed this mb +amd64 3000 running xp pro worked fine for about month -
it then lost the drivers for the on board network adapter and will not
re-install them voluntarily - I have to force the install. When booting up
it appears to get an ip address in the correct range usually
192.168.2.120-130 but I can't ping anything on the network even the router
that gave it the ip address
Any ideas - ive tried installing/uninstalling no luck it doesn't appear to
recognise the adapter but knows there is an ethernet device present
Help
Nik
Help
Nik
