I am currently using a corsair h55 Liquid cooler and on the instructions it says "for best performance, make the back system fan an intake" I'm assuming it's so that the radiator will be cooler. My problem is, that I do not have a spot for a top case fan on my case, but I do however have a bottom slot. (I am open to doing case mods however) and my mobo peaks at a temp of 85C when under load. (namely BF4) I use Open hardware monitor to check all my temps and it is really only the mobo's temp that is concerning me.
Would you recommend using the back as an intake? and
What could help me with my hot mobo?
My build:
AMD FX 8350 (stock speed)
Corsair H55 Silent edition Liquid cooler
MSI 970A Krait edition MOBO
Ultra Gladiator Mid Case
MSI GTX 960 4GB OC Edition
My build:
