lag problem (big fps drop) help!?!? no solved yet
viljami323
72
So for some reason i have really big lag and fps drop. when play tf2 normally 299fps at the menu now 50. at game 120 now 25. why is this happening? My friend said that its driver bug or something like that. and this is in any game not tf2 only
Pc specs
ASUS GeForce GTX 660 OC DCII 2GB GDDR5
amd fx-8320
ASUS M5A97 R2.0 AM3
XFX 450W PRO Core Edition V2 Full Wired 80+ BRONZE
KINGSTON HYPERX 8GB 1600MHZ DDR3 (2x4GB)
win 7 64 bit
That's certainly odd, I'd probably set my modem to factory default and do the quick setup again
Either that or you may have a background program constantly connected to the net and operating whilst you're in games
A conflict between your modem and GPU? that's quite a rare sight, and glad that the card itself is good since it's at 99% usage
but i have same problem in another games too. but yesterday after posting this i tried to install diver and reeboot my computer. after many times it worked! . and now i have same problem again. i don't think that the problem is in the drivers. does it have something to do with bios?.
What PSU do you have? You never mentioned that, there can be issues on system load as well. First of all upgrade your bios and load optimized defaults so that can be eliminated. Then run aida at full load for an hour, see if it breaks down or not. Also load coretemp and post your temp readings to us while aida is running
sorry my bad English but did i understand you correctly
So i run pc in safe mode. then i uninstall Nvidia drivers with that tool.
is it good if get newest drivers to memory stick and install them form there?
so what do you think i just re installed drivers
