lag problem (big fps drop) help!?!? no solved yet
viljami323
72
So for some reason i have really big lag and fps drop. when play tf2 normally 299fps at the menu now 50. at game 120 now 25. why is this happening? My friend said that its driver bug or something like that. and this is in any game not tf2 only
Pc specs
ASUS GeForce GTX 660 OC DCII 2GB GDDR5
amd fx-8320
ASUS M5A97 R2.0 AM3
XFX 450W PRO Core Edition V2 Full Wired 80+ BRONZE
KINGSTON HYPERX 8GB 1600MHZ DDR3 (2x4GB)
win 7 64 bit
That's certainly odd, I'd probably set my modem to factory default and do the quick setup again
Either that or you may have a background program constantly connected to the net and operating whilst you're in games
A conflict between your modem and GPU? that's quite a rare sight, and glad that the card itself is good since it's at 99% usage
OMG now i found what makes my computer laggy! i dont know why. but its internet connection! when i am connect to internet games are laggy. and when i disconect i get my good 200 fps back! so why is this hapening?
and now it works again! what i did i closed program from task manager called dlhost.exe and now it works perferfly no problems at all!
and now it works again! what i did i closed program from task manager called dlhost.exe and now it works perferfly no problems at all! and GPU usage is now 1% only
