Lag Spikes with Fraps while recording Minecraft..
Spencer JC
19
I have been using Fraps to record, and I seem to be getting lag spikes while recording Minecraft. I've been debating if it's because I record on to my internal hard drive, but I'm not sure.
Here are my specs:
Intel Core i5-3350P 3.1GHz
EVGA SuperClocked 02G-P4-2662-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
8 GB DDR3 Ram
1 TB Hard Drive
450 Watt Power Supply
1680 x 1050 Monitor
As far as I know, you'll experience lag while recording anything with Fraps. I'm not sure if it's because you're writing to your disk, but I know that Fraps intervenes and takes a picture of every frame of the game, which will decrease performance.
Tips for smooth recording:
- However many CPU cores your game uses, you should add +2 for recording/compressing/writing to disk
- Turn Crossfire/SLI off. Game capture software generally performs better when capturing off 1 GPU
- Have a dedicated hard drive used for NOTHING but capturing video. Keep it clean.
- 8GB or more of DDR3 RAM of the fastest speed supported by your CPU
- Record @ 30FPS in one of these standard widescreen resolutions: 1280x720, 1600x900, 1920x1080
- You 'can' record multuchannel audio *OR* downmix to stereo. Multichannel is a direct stream copy but larger file. Downmixing uses a little bit of CPU power to remix multichannel to 2 channel stereo, but is a slightly smaller file
It is probably your system hard drive being too fragmented and busy to record and write smoothly.
The thing is though, Minecraft is incredibly easy to run. I get around 400 fps while playing, so it must be the hard drive.
It seems like you copy/pasted that, 30 FPS in a game like Minecraft looks like a choppy mess, and I obviously have 8 GB of ram and no SLI. Though, I will think of getting a separate hard drive for recording.
