jacobweaver800 :
aeraer468 :
Running at FPS lower than what the monitors refresh rate is fine, try your old monitor and see if it persists. Also are you using an adapter?
My FPS doesn't go lower than 144hz, im using a DVI for the monitor
Just went back to the 144hz and turned of the vsync the stuttering still happens.
What FPS are you getting? Usually high FPS like over 200 FPS will cause stuttering, try switching to a V-Sync monitor that should smooth out the frames and remove the stuttering.
