Hi all, i have a strange problem, might be bug in firmware
I use Asus router with Merlin firmware. Very strong 2.4 and 5 Ghz signals around house.
Router has a WD Network Drive wired direct it shares Dlna movies and shows as a storage space.
When i connect to the 2.4Ghz Wifi on a laptop or pc or phone, i can see the NAS. Also my TVs while on 2.4Ghz wifi also see the NAS and can stream movies.
Windows 10 also shows shortcut to NAS, and so all working as it should.
However if any device connects to the 5Hhz WIFI the NAS is no longer available.
So, NAS on LAN, device on 2.4G works
So, NAS on LAN, device on 5Ghz does not work.
Cant see any settings in router to disable devices seeing each other, unless using Guest WIFI, where there is a setting to stop a guest from seeing your home devices
RT-AC86U and 2 x RT-AC87U routers, all three routers have same problem.
Tv on 5ghz no NAS shown
Pc on 5ghz no NAS shown
Thanks
All routers latest Merlin firmwear problem started about 3 firmware upgrades ago
Thanks
