LAN connection problems with BF1942 and others
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.action (More info?)
Hello,
I've been trying to set up a LAN session for various games and I've
been having some minor problems. I have two machines and sometimes I
can host a game on machine A and Machine B can't see it, but if
Machine B hosts, machine A can see it. Has anyone seen something like
this and if so, what things can I try to fix it?
Thanks,
* Robinson
Andrew
2,439
On Mon, 24 Jan 2005 10:03:57 -0500, Mirror Spock <robins80@msu.edu>
What is your network setup? Are you running a firewall?
Andrew, contact via interpleb.blogspot.com
Help make Usenet a better place: English is read downwards,
please don't top post. Trim replies to quote only relevant text.
Check groups.google.com before asking an obvious question.
G
Guest
Guest
On Mon, 24 Jan 2005 16:15:09 +0000, Andrew <spamtrap@localhost.>
Two machines hooked up to a hub (probably not the answer you're
looking for). I have the XP default firewall, but I have already
taken the steps to allow the games to go through.
* Robinson
