LAN does not have valid IP
nickknikky
5
using the lan cable I can connect to internet on my laptop bt when I connect the same cable on my desktop it does not work. please help me guys.??
IP Config for my laptop:
Windows IP Configuration
Host Name . . . . . . . . . . . . : NIK
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Mixed
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter vEthernet (Broadcom 802.11n Network Adapter Virtual Switch):
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #3
Physical Address. . . . . . . . . : C0-14-3D-C7-46-2F
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Ethernet adapter vEthernet (Qualcomm Atheros AR8162 8166 8168 PCI-E Fast Etherne
t Controller (NDIS 6.30) Virtual Switch):
Description . . . . . . . . . . . : Hyper-V Virtual Ethernet Adapter #2
Physical Address. . . . . . . . . : 3C-97-0E-2B-D8-00
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::654b:4527:5fb0:cb0a%22(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.50(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 456955662
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-19-D0-9B-96-3C-97-0E-2B-D8-00
DNS Servers . . . . . . . . . . . : 59.179.243.70
203.94.243.70
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : C0-14-3D-C7-46-30
Wireless LAN adapter Local Area Connection* 11:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : C2-14-3D-C7-46-2F
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
IPv6 Address. . . . . . . . . . . : 2001:0:5ef5:79fb:8b0:3f45:3f57:fecd(Prefe
rred)
Link-local IPv6 Address . . . . . : fe80::8b0:3f45:3f57:fecd%18(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 570425344
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter isatap.{111173B6-297F-4A39-A415-CE2EAAA882CF}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #5
C:\Users\Nikki>
IP Config for my desktop
Host Name . . . . . . . . . . . . : MALIK-PC
Node Type . . . . . . . . . . . . : Hybrid
Ethernet adapter Local Area Connection:
Description . . . . . . . . . . . : Atheros L2 Fast Ethernet 10/100Base-T Con
troller
Physical Address. . . . . . . . . : EF-9F-E9-F7-F7-F7
Link-local IPv6 Address . . . . . : fe80::30b2:3fde:261f:bc2%11(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.10(Preferred)
DHCPv6 IAID . . . . . . . . . . . : 250585065
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-03-C2-87-B4-EF-9F-E9-F7-F7-F7
203.94.243.70
Tunnel adapter isatap.{D5FC0B73-7805-481C-8F24-B5D87F399C74}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2
C:\Users\MALIK>
troller
203.94.243.70
C:\Users\MALIK>
for my laptop both static and auto IP works fine.. bt none works for the desktop. bt the above config results are for static IP
