B BShiv Jul 3, 2019 10 0 10 Jul 16, 2019 #1 I tried to update UEFI(BIOS) of my IBM server X3250 M4 with the help of Lenovo Update Xpress System PAck Installer but on updating its shows the error "LAN-over-USB device not found".
Fix_that_Glitch Judicious Mar 31, 2019 7,084 815 32,940 Jul 16, 2019 #2 did you update it using a usb slot? Upvote 0 Downvote
B BShiv Jul 3, 2019 10 0 10 Jul 16, 2019 #3 No. I'm updating it directly through "Lenovo Update Xpress System PAck Installer ". Upvote 0 Downvote
Fix_that_Glitch Judicious Mar 31, 2019 7,084 815 32,940 Jul 16, 2019 #4 What os you using? Upvote 0 Downvote
Fix_that_Glitch Judicious Mar 31, 2019 7,084 815 32,940 Jul 17, 2019 #6 Ok so go to Network properties, disable the usb interface , then enable it. See if that helps. Upvote 0 Downvote
B BShiv Jul 3, 2019 10 0 10 Jul 18, 2019 #7 Fix_that_Glitch said: Ok so go to Network properties, disable the usb interface , then enable it. See if that helps. Click to expand... I have checked and found there are no any USB interfaces . Upvote 0 Downvote
