So I googled around even looked at other threads, but nothing works so far. I tried all the reset commands, one of the lines stated "Resetting , failed.Access is denied." ( I did run as admin). The LAN cable didnt pick up till I did the 10mbps duplex fix, now its stuck on identifying.
Help would be appreciated!
Windows IP Configuration when USB Wifi adapter removed and ETHERNET CABLE ONLY.
Host Name . . . . . . . . . . . . : DESKTOP-FT776CO
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : 30-9C-23-82-DE-4A
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::ec7d:b85d:c580:5b96%11(Preferred)
Autoconfiguration IPv4 Address. . : 169.254.91.150(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 187735075
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-22-01-3C-DB-30-9C-23-82-DE-4A
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Windows IP Configuration when ONLY WIFI is in.
DNS Suffix Search List. . . . . . : Home
Wireless LAN adapter Local Area Connection* 9:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : 7E-8B-CA-1A-C9-26
Wireless LAN adapter Wi-Fi:
Connection-specific DNS Suffix . : Home
Description . . . . . . . . . . . : TP-Link Wireless USB Adapter
Physical Address. . . . . . . . . : 7C-8B-CA-1A-C9-26
Link-local IPv6 Address . . . . . : fe80::e40e:8e82:9902:d9be%2(Preferred)
IPv4 Address. . . . . . . . . . . : 10.0.0.7(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Monday, 19 February 2018 20:52:40
Lease Expires . . . . . . . . . . : Tuesday, 20 February 2018 20:52:45
Default Gateway . . . . . . . . . : 10.0.0.2
DHCP Server . . . . . . . . . . . : 10.0.0.2
DHCPv6 IAID . . . . . . . . . . . : 41716682
DNS Servers . . . . . . . . . . . : 10.0.0.2
IPv6 Address. . . . . . . . . . . : 2001:0:9d38:6abd:73:446:961c:bc5c(Preferred)
Link-local IPv6 Address . . . . . : fe80::73:446:961c:bc5c%8(Preferred)
Default Gateway . . . . . . . . . : ::
DHCPv6 IAID . . . . . . . . . . . : 352321536
NetBIOS over Tcpip. . . . . . . . : Disabled
fec0:0:0:ffff::2%1
fec0:0:0:ffff::3%1
