Hi everyone. I have set up multiple routers with the same network to extend wireless coverage at home since it has so many levels and walls but I'm not entirely sure if I did the right thing. Here's the set up:
ISP MODEM ROUTER
192.168.1.254
DHCP: ON
ROUTER 1/SSID 1
192.168.1.1
DHCP OFF
ROUTER 2/SSID 2
192.168.1.2
DHCP OFF
ROUTER 1/SSID 3
192.168.1.3
DHCP OFF
ROUTER 4/SSID 4
192.168.1.4
DHCP OFF
ROUTER 5/SSID 5
192.168.1.5
DHCP OFF
Routers 1 to 4 are connected to the ISP Modem Router via ethernet cable and Router 5 is over to the Router 4. 1. Is there something wrong with this set up? Does it matter if one router connects to the other router and not necessarily from the main ISP modem router?
2. Routers Wifi range somewhat overlap to each other so should I change each channel as well?
3. Is there any difference if I switch to LAN to WAN? I'm not actually familiar with this set up but my friend told me that LAN to WAN is much easier. Not sure though.
I'm not really familiar with the networking stuff but I just checked some tutorials online. Your help is highly appreciated.
ISP MODEM ROUTER
192.168.1.254
DHCP: ON
ROUTER 1/SSID 1
192.168.1.1
DHCP OFF
ROUTER 2/SSID 2
192.168.1.2
DHCP OFF
ROUTER 1/SSID 3
192.168.1.3
DHCP OFF
ROUTER 4/SSID 4
192.168.1.4
DHCP OFF
ROUTER 5/SSID 5
192.168.1.5
DHCP OFF
