Lapping a cpu and heatsink stages
Naw, why do that? Just Lap them both, get yer extra 5-7 c in low temps, OC it till ya reach a Max core temp of 75 in yer hottest core in prime 95 with all 4 cores over hours time. You'll note that it will get to a max temp, then settle near 4 c under it for the upper end of the tests. Like 1-2 hours into it. Let it get its 8 hours, and adjust Vcore accordingly. In day to day use you'll never see its max temp. Crysis and all that junk. (Music in the background and various stuffs.) I think my one hot core gets to 60.
Some will say never go over 65! I have had mine up to 92 and still here. And huge voltages, was 1.81250 in the bios, 1.78 in windows, sooo... they wont just pop.
--Lupi
Nope, can I DL the client? I just use pidgin, which is an AIM client. If I can DL it, just point me to it and I will. If not, everyone knows where AIM is!
--Lupi!
Well, that was an accident, but the cores were only 85c since it was only at 2.88 Ghzs. I have cranked it at full power and gotten up to 92c while testing with prime. BUT... I do know that it didnt break or get damaged YET at these extremes. Isnt that what OCing is about? Extremes?
--Lupi!
Lupi, I'm getting ready to head over to the hardware store and get some sandpaper to lap my Q9450 and TRUE, using what you've written. Wish me luck!!!!
