Question Laptop ASUS GL552VX suddenly won't turn on after using nbtstat -R and -RR
Jul 12, 2019
Hi,
I just had a problem with my ethernet connection stating Ethernet doesn't have a valid IP address. I look up on internet how to solve it and got some solutions to try (https://www.drivereasy.com/knowledg...e-a-valid-ip-configuration-on-windows-solved/). At first, I tried method 1 and 3 but didn't work, so I moved to method 4, but when I want to restart my laptop, I wrongly pressed the button to shutdown instead of restart, since then my laptop won't turn on at all, not even a slight process happening no matter how many times i pressed the power button. Is it possible that this is caused by software issues?
It seems like my laptop suddenly has gone back to normal, but i still don't know what causes it. When it's on, it works perfectly fine, no issue whatsoever, but as you said it seems like not a software issue either, so yeah it's weird but I think for now the problem is resolved. Thank you
Reactions: rgd1101
