Laptop Charger Working When Cable Is Rolled
Apr 22, 2018
I have some strange problem: Laptop charger doesn't work several days if I use it as is, but when I roll certain section it charging laptop again. And after if I do straightening charger cable while it charging it won't stop the charge. I don't understand what it is. And what can I do about it? Pls, give me some tips what it could be. Thx
Well, the cables inside the casing that you're looking at can break their insulating, this may cause a short along a particular stretch of cable. Now, there's only really one solution that you can use to fix this- which is to buy a new cable. Now, I understand that its extremely annoying when something doesn't go your way, but you can possibly make due with what you've got.... Or you can buy a new cable and all of your problems will go away.
Thanks, for your time. Yes, I have another charger with lower wattage but I did not want to cut the cable and do "dirty" work for cosmetic reasons. But thank you anyway for reply. :)
