Laptop charging for a second then the orange light up and disappears and can't turn on.
Can anyone help me. My ASUS laptop couldn't turn on. It was happened when I drained the battery and not charging it for 2-3 days. Then on another day, I start turning on and still no power. Then I tried to charge it. For 1 sec the orange light indicator lightens up then it disappears. Can someone help me. My battery is built in I don't remember the exact unit.
NOTE: Yes, I know some batteries are not so easy to get to, on some devices. However, it should be removable/replaceable. Unless it is under warranty, then you should contact the manufacturer first.
Try the following and see if it will turn on...
1. Unplug your charger cord.
2. Remove the battery.
3. Press and hold the "Power" button for 30 seconds.
4. Now plug back in the power/charger cord.
5. Now put the battery back in.
If this doesn't help, then test the power cord to see if it is good. Either try your cord in another device, or try another devices cord in your laptop. You may also want to try charging it when the device is off, rather than on. If it works then, the cord is probably the issue.
Should that not be the problem...
Should that not be the problem, then check the battery to see if it needs replacing.
