Hello all, I have a recently bought Samsung QX411 laptop and I found its CPU temp to be moderately high at idle and very high under load. It runs at about 40-50 degrees Celsius just idling and gets all the way up to an average of about 80 degrees Celsius while playing team fortress 2. I still have until this Sunday, October 2nd to return the computer if I must, so I was wondering: are these temps acceptable? Or will they lead to a significantly reduced computer life? I do plan on gaming with it quite often so it would be nice to know if 80 Degrees will harm the i5 2410m this thing has in it. I do know that 80 degrees used to be a killer temp, but if I understand correctly, these newer i5 can handle it better. If it is indeed too hot, do you have any suggestions for another 700$ or less computer to get instead? On another note, would a cooling pad make it usable for gaming without getting another computer?
Thanks in advance for your advice ^^
