So I have an Acer nitro laptop that normally works like a charm, but has one annoying problem.
Whenever it is bumped or moved, or even if I hit the enter key with too much enthusiasm, it will crash.
Then if I attempt a restart, the startup light will come on without the laptop actually starting, or occasionally starting and immediately crashing straight after.
After 2-4 restart attempts it will start up normally again.
I'm no expert, but I've ran harddrive checks (no errors), reinstalled Windows, cleaned fans with compressed air, checked against loose wires, and checked the temperature readings directly after a crash. As a whole, the crashes don't appear correlated with heavy use (could occur directly after being turned off for long times). Nor are there any error messages I can find.
Any help would be greatly appreciated
