laptop cursor problem when charging
sudipta123
Commendable
Oct 5, 2016
my laptop model is asus x450cc..my main charger of my laptop is collapsed few days ago..i bought a new charger but my problem is when i connect the charger and touch the touchpad my cursor move so fast,jumping and work automatically..but when i disconnect charger cursor work well..what can i do now?????
Did you perchance get an after market charger cord? If that is the case, it may be sending out signal that is causing the issue, by causing interference.
I would suggest trying a different charger cord to see if it is that. If so, you may want to consider going OEM for the part.
