laptop fan running max speed
G
Guest
Guest
Something wrong with my laptop fan. It always running at max speed.
At first I thought there was a problem with the cpu load and temp. But when I check with Core Temp, they seems operate in normal temp.
So I check again with SpeedFan, then there are some weird reading.
The temp1 reading is imposible (429496448C, its hotter than the sun) and it doesn't change over time (min, max, and mean are the same).
Based on image above, temp1 related to ACPI chip or something.
Is there any way to fix this?
My laptop is Fujitsu Lifebook L Series with Windows 7 x64 OS, Intel Core i5-2430M @ 2.40 GHz, 4 GB of RAM.
Sorry for my broken English.
Mark_1970
1,391
Disregard the speedfan app, it is not configured to your pc correct. Laptops trap dust inside the heatsink fins, once near blocked, the thing gets way hotter, the fan will be stepped up to cool more. clean this out
