Hi Everyone,
My cousin gave me her Toshiba Satellite (I believe L455D-S5976, http://us.toshiba.com/computers/laptops/satellite/l450/L455D-S5976/) laptop to try to fix. At first she thought the hard drive went bad, but I started up the computer and it loaded up but when it tries to load windows it gives an error message about missing files or missing something that deals with boot, so I'm assuming her boot information is corrupted and hopefully I can do a recorvery/restore for her. I don't think I can boot into Safe Mode. When I do f8 the computer gives me a list of options with "recovery console" as the most prominent option to use. Before I attempt any of this recovery/restore stuff I want to pull what files I can find for her as they are her portfolio work for her photography.
So I pulled the hard drive out and hooked it up to my computer (Intel i5, windows 7 pro 64bit) via an IDE/SATA to USB adapter. I know the adapter was recognized because it made a "duh dunt" sound telling me something is plugged in, but it did not bring up the hard drive. It seems like the hard drive wasn't spinning, so after lightly messing with the adapter's cables (I lift the power cable up a little bit and it seems to fix the connection), I got the hard drive to start up and it was spinning. Still not recognized by the computer and I am not finding it in my "disk management" screen.
She is prepared to buy the recovery/OS discs from Toshiba so it will not be a problem to reinstall a fresh OS. But, I really need to salvage what I can of her work/files. My question is does anyone have an idea of how I can get the adapter to work or another way I can pull the files off the laptop hard drive?
Also, I do have an Acronis system repair/cloning program (actual retail version from Tigerdirect)... Would this be able to help me out? I don't know why I haven't thought about it until now... I know the cloning will not help because I'd only be cloning the damaged filesystem.
Thanks in advance!!
Thanks in advance!!
