T TimothyG36 Reputable Nov 27, 2014 21 0 4,510 Dec 18, 2014 #1 How do i copy everything from my window 7 laptop to my 1 tb external hard drive? Step by Step plz. thx
Solution ThatVietGuy Dec 18, 2014 Are you trying to transfer Windows? Because if you are that's not how it works. If you want to back up specific files then you have to find those files and drag and drop them to the external hard drive.
ThatVietGuy Titan Nov 6, 2007 11,723 316 70,240 Dec 18, 2014 Solution #2 Are you trying to transfer Windows? Because if you are that's not how it works. If you want to back up specific files then you have to find those files and drag and drop them to the external hard drive. Upvote 0 Downvote Solution
T TimothyG36 Reputable Nov 27, 2014 21 0 4,510 Dec 18, 2014 #3 ThatVietGuy : Are you trying to transfer Windows? Because if you are that's not how it works. If you want to back up specific files then you have to find those files and drag and drop them to the external hard drive. I'm trying to remove everything to the hard drive and reboot my laptop so it will run faster Upvote 0 Downvote
ThatVietGuy Titan Nov 6, 2007 11,723 316 70,240 Dec 18, 2014 #4 You're only going to be able to move "regular" files (e.g. videos, MP3s, documents, etc.) by dragging and dropping. If you try to move programs and the like and then move them back after a reinstall they're not going to work. Upvote 0 Downvote
