Laptop: no post, no fan, even only with essential parts
SamDavis
4
I put the computer to sleep mode, and then I went out for an hour. I came back and tried to wake it up to a blank screen. I forced a hard boot, and got a blank screen again. Then, I took it apart to essential parts and noticed the fan wasn't moving in the slightest. I took out the motherboard to isolate from the case and it didn't help. Removing the 3v mobo battery, and draining power via power button while disconnected didn't work. Letting it sit for 8 hours with drained power didn't help.
No POST.
No fans.
Only LED that turns on at power button press until I remove power jack turns on, otherwise nothing else to note.
Only CPU, 1 of 2 RAM, screen, power, cpu fan, and power button are connected. Motherboard isolated.
I figure it's the motherboard, but I can't afford a new PC. I'm willing to work out the components and read volumes if I need to, and maybe buy inexpensive tools since I could do with the extra technical skills and economic opportunities that such tools provide. I'm currently studying a book to help fix circuit boards, but any online resources on the subject of circuit board repair will still be appreciated.
I have to be honest: I got awfully paranoid that maybe someone online hacked my BIOS and corrupted it, but is that even a thing? I was running a trial of EVE Online just before I put the computer to sleep, and often click the random links I find on people's profiles. Some guys were trying to troll me and I did click on some links in their profiles. Also, a family member handed me their laptop to fix that I haven't had the chance to work on, but I was told they had the same symptoms. This was just a week before my computer went out, so I thought maybe there was such a thing going around--it would be a new reality to me, but conceivable.
I didn't include the specs in this post because I thought that it isn't particularly applicable.
with the laptop check the voltage of the ac brick. if it to low or to high it can cause issues. use a volt meter and read the voltage output. check on the brick that the wires are not broken and on the laptop the power pin not broken. (broken pin or soilder join can cause the pin to short the motherboard out. pull the hard drive and use one ram stick and ext monitor port t rule out an lcd backlight failure. if not change pull all the ram see if the laptop mb beeps. if there no beep or post could be the laptop over heated. one thing to check on line is class action lawsuit on your laptop. over the years there been bad batteries recall. nvidia had a bunch of bad video chips end up on laptop system boards. there also been bad caps and some...
with the laptop check the voltage of the ac brick. if it to low or to high it can cause issues. use a volt meter and read the voltage output. check on the brick that the wires are not broken and on the laptop the power pin not broken. (broken pin or soilder join can cause the pin to short the motherboard out. pull the hard drive and use one ram stick and ext monitor port t rule out an lcd backlight failure. if not change pull all the ram see if the laptop mb beeps. if there no beep or post could be the laptop over heated. one thing to check on line is class action lawsuit on your laptop. over the years there been bad batteries recall. nvidia had a bunch of bad video chips end up on laptop system boards. there also been bad caps and some vendor with high doa system boards. your laptop may have a recall on it that let you get a new unit or system board.
Volts read 19v DC output, as is on the AC adapter. Laptop inlet is fine/no broken pins. Ext mon had nothing. It wasn't overheating since I monitor for heat and regularly replace the thermal paste (once per 2 years or so), and I can feel the heat as I'm using it.
I checked for recalls and found none.
Model: Toshiba Satellite c655d-s5087
I appreciate your effort smorizio. Thank you.
Some extra info: The AC power LED on the laptop goes on when the adapter is connected. There's two LED for power though. One that shows that the AC adapter is connected, and another that the laptop is actually turned on.
The AC adapter signal does turn on, and when the power button is pressed, so does the other LED. The fan does not respond to the power-on.
Also, I noted that when the power button is turned on, the CPU actually starts warming up, but there's no beeps.
